NO SPARK! :(
Lewis117
Hi all
1995 LT1, fans stopped working and popped a radiator few months back
Fitted a new radiator and thermostat, new spark plugs and oil change while I was at it
Car ran fine, coolant stayed within operating range
Then on the M6, oil got very hot (coolant was still fine) and engine lost all spark
I have now changed the optispark and the coil.... But I'm still getting no spark
Anyone have any advice please cause I'm really getting to the end of my patience with this car now which is sad because I used to love it
You need to find out if in fact the engine oil is hot or the sensor is bad or a wiring issue ?
What is the temp reading showing on gauge with just key on and engine off ?
Have you checked fuses to see if any are blown ?
Does the security light on the dash flash when the door is opened ?
If you have an interest in the gm engineering of design and specs for 1995 Corvette
Below I attached GM document in PDF form and is 165 pages long
  • 1995-Chevrolet-Corvette.pdf
