trevbeadle
I'm about to attempt a carb transplant on my 350 Mexican Goodwrench engined Corvette. The current carb is, I'm told, a mid eighties ECM contolled truck carb with no adjustments. The car as far as I am aware does not have ECM! Can someone answer the following questions?
What is the vacuum diaphragm on the right of the pic on the existing car? What did it do/should it do/ does it need to do? it looks like a vacuum pulloff that should have a linkage to the vacant post on the throttle lever.
the rear vacuum pulloff on the choke is not present on the replacement carb. Do most Qjets have 2 or is this an ECM abberation? Is one sufficient and normal?
I think the vacuum port on the right will be redundant as there is and electrical connection in that position on the old carb. Do I just cap it off with a rubber piece/bolt or should it connect to something?
Likewise, this top port seems redundant?
Grateful for any advice or additions. Thanks.
