Adtheman
Hi There. Any of you guys running a Dewitts rad with dual Spal electric fans. If so where is the temp relay sender. Ive got mine in the rad but it doesn't seem to get quite hot enough in that part of the rad where the sender is. Changed out from a 195 to a 185 but not seeming to cut in. Its almost as if the rad is far too efficient for its own good. Manual override all working fine so i know the wiring is good. The temp gauge in the car is running around 210/220 which i know are not that accurate but it is getting hot. Its hotter on the top hose and thermostat housing than the area of the rad where the switch is. Other option is to re route the sender unit to the cylinder head, bit annoying as this should work where it is.
