Daniel B
I'm looking to get a replacement radiator and its turning into a bit of a minefield so reaching out for a bit of advice...
I've got a small block 72 with what is now a 383, on an auto box with AC. Unfortunately the radiator is leaking and its just that little bit too much for me to turn a blind eye to so I'm assessing my options. Since removal appears to be quite a procedure compared to rads I've done in the past I've decided to replace it completely with new rather than try and fix it, so I'm looking for replacements.
I've checked through all the documentation history I have for the vehicle (it appears to be comprehensive) and all I can find was a radiator refurbish in 1996, so from what I can tell this is the original that is fitted. However it doesn't appear to match what I'm seeing online?
The rads shown online for a 72 SB C3 appear to look like this but this is nothing like mine; its narrower, there's no transmission cooler, there is no filler cap and the pipe exits are in the wrong place. I'm presuming it must be for the manual maybe?
In fact one of the very few radiators I can find online that is anything like mine is this Cold Case CHV714A which is interestingly listed for a 69-72 SB but as we know websites often use generic photos so who knows if what I am looking at is what they are selling.
The way I am identifying it as matching mine is:
Filler cap present and in the right place.
Inlet and outlets pointing in the right direction.
Both transmission cooler points are between filler and outlet on the right.
Drain plug in the right place.
So I guess my questions are...
Does my C3 actually have the original radiator or has it got and upgraded one or one from a later/different model?
(I think it is original as the later models appear to have one of the transmission cooler connections below the outlet?)
Can anyone recommend a source of a replacement radiator or will I need to either battle with the Chinesium on ebay/amazon or import the Cold Case from the states?
UPDATE: I got a couple of prices from UK suppliers for the Cold Case; one was super crazy high, one wasn't too bad but the Cold Case is quite expensive to begin with and I have no idea if they are actually any good.
