revolution electronics.com c5-corvette-abs code clear
C2 VET
Found this device in the States that clears the ABS code on C5's.
Apparently it flashes the ABS light three times and then turns it off, no codes etc, an alternative to $2k secondhand ECBM's.
The only problem is when I emailed to buy one they have been advised by their underwriters not to sell them !
Maybe someone on here could work out how it works.
There is aPDfF installation guide that might help.
Pitre
Interesting. I've also seen an article on a US forum where a later model EBCM has been successfully installed on a 97-00 C5.
So it does seem like there is a tiny bit of light at the end of the tunnel, but it's still poor from GM that there isn't a proper solution...
Another possibility HERE
