I have found a 'Lubricating the Cable' document that I copied from the Willcox Corvette site some years ago. Have just looked for it on Willcox but it seems the document is no longer available. Anyway, this is a summary what it says:
- All cables assembled from bulk stock must be lubricated before installation
- in extremely hot and dusty conditions, relubrication may be necessary at intervals of approx. 20,000 miles or 2 years
- AC has developed a Type ST-640 speedometer lubricant. This assures free running in extreme temperatures and prevents rust and corrosion
- Only AC ST-640 lubricant should be used. Other lubricants will work their way up the cable and into the speedo/tach head
- The cable should be lubricated ONLY along the lower 2/3 of its length
- Place 'one inch' of lubricant in palm of hand
- Feed the cable through the lubricant in you hand until the ;lower 2/3 is lubricated
- Cable operation will lubricate the upper 1/3
- Excessive lubrication will force grease into the speedo/tach heads and will stop the speed cups from operating properly
For reference, I last lubed my speedo & tach cables in 2008, using Moly chassis grease as I could not locate any AC Type ST-640. I used the procedure as outlined above. That was about 46,000 miles ago now and my speedo and tach are both still working OK.
Chris Sale
'64 Coupe
