Here's what I've done to my thermostat to resolve a problem....
After rebuilding my engine and making it a 383, I had been getting a puzzling temperature issue. As the engine warmed up the temperature just kept climbing higher and higher, up to an alarming 220 -230 degF. Just as I was about to switch the engine off, it would start to drop back to a more comfortable level. When driving, if I stepped on it even for a short time, the temperature would spike again. I've got a big electric fan cooling a stock radiator. ally heads and a high flow pump.
My initial thought was either a sticking thermostat or an airlock. I removed the 180deg thermostat and confirmed that I had already got a 3mm hole drilled in it to prevent an airlock. I did a test in a pan of boiling water that showed it to be opening fully.
As an interim measure I tried running the car with no thermostat and sure enough, no spiking temperatures but instead generally running too cold. Temps a bit all over the place, suggesting that a thermostat was needed to regulate it.
I tried a new 160 thermostat, again with a 3mm hole drilled in it to prevent an air lock. Result was exactly the same - temp shooting up alarmingly high on warm up and also when stepping on it.
I decided to to try an idea - I drilled a series of 5mm holes around the thermostat flange. Theory being the holes will allow an amount of water flow even before the 'stat opens and then when it does open, throughput is increased further. Result - no more temperature spikes. The engine still warms up normally and then stabilises at 170. If I gun the motor the temp will rise but the fan will bring it back down.
