TSB for C8 Center Console
The center console compartment release button on some 2023-2025 Corvette models may become stuck in the depressed position or may extend out of the console compartment. If these conditions are found, the console compartment release button should be replaced.
It’s not necessary to replace the complete console armrest latch assembly.
Push-button Available as Separate Part
The spring-loaded push-button (PN 85133773) is available as a separate part without the latch assembly and can be ordered through the regular GM CCA parts process. Use the Vehicle Identification Number (VIN), Service Information (SI) and the GM Electronic Parts Catalog (EPC) to determine the correct part number to order.
To release the console compartment door when the push-button is inoperative, insert a plastic trim tool behind the button.
With the compartment door open, use the trim stick to release the push-button from the latch assembly
Check that the spring remains with the push-button. If it does not, use a suitable tool to remove it from the armrest latch.
The spring and latch slider should be transferred to the new push-button.
Use Correct Labor Code
Different labor codes are available for replacing only the center console push-button and replacing the latch assembly.
Be sure to use the correct labor code that most closely matches the repair. Labor code 1036140 has been released for replacing only the console push-button.
For more information, refer to Front Floor Console Compartment Door Latch Push-button Replacement in the appropriate Service Information.
I will admit that part is crap and very flimsy feeling, notchy and doomed to fail so I don't put anything in there
