Adtheman
I just wanted to share this info as when i bought my C3 it was not running as it should, basically someone had at some point shoved a Holley carb on and not bothered setting it up. result was cutting out backfires, a nightmare to drive, I was given Pauls number by a friend and off i went to see him. A few hours later carb was of stripped and cleaned, put back together with new gaskets, choke removed and set up properly and timing done. In all there was about 6 hours work. He charged me only £160 for this work. The car now drives and idles beautifully. They do all work to pre FI V8 engines. If you are in Norfolk and need a go to guy you wont go wrong by giving Paul a call on 01603 812055
