Vin Number
It is a 2000
  • Basic
  • Model Year
    2000
    Make
  • Series
    Corvette
    Trim Level
    Coupe
  • Origin
    UNITED STATES
    Body Type
    COUPE 2-DR
  • Dimensions
  • Track Front
    62.10 in.
    Passenger Volume
    51.40 cu.ft.
  • Height, Overall (in)
    47.7
    Track Rear
    62.20 in.
  • Wheelbase (in)
    104.5
    Cargo Volume
    24.80 cu.ft.
  • Ground Clearance
    3.70 in.
    Wheelbase
    104.50 in.
  • Height
    47.70 in.
    Front Legroom
    42.70 in.
  • Width
    73.60 in.
    Length
    179.70 in.
  • Front Hip Room
    54.20 in.
    Front Shoulder Room
    55.30 in.
  • Width, Max w/o mirrors (in)
    73.6
    Front Headroom
    37.90 in.
  • Turning Diameter
    40.00 in.
  • Drivetrain
  • Transmission
  • Vehicle Stability Control System
    Optional
  • Traction Control
    Standard
    Engine Type
    5.7L V8 OHV 16V
  • Driveline
    RWD
  • Braking
  • ABS Brakes
    Standard
    Anti-Brake System
    4-Wheel ABS
  • Rear Brake Type
    Disc
    Front Brake Type
    Disc
  • Suspension
  • Rear Spring Type
    Leaf
    Front Suspension
    Independent
  • Rear Suspension
    Independent
    Front Spring Type
    Leaf
  • Steering Type
    Rack & Pinion
  • Colors
  • Exterior Color
Interior Trim
  • Seating
  • Standard Seating
    2
    Leather Seat
    Standard
  • Driver Multi-Adjustable Power Seat
    Standard
    Passenger Multi-Adjustable Power Seat
    Optional
  • Weight
  • Curb Weight
    3246 lbs
  • Safety
  • Vehicle Anti-Theft
    Optional
    Power Door Locks
    Standard
  • Driver Airbag
    Standard
    Passenger Airbag
    Standard
  • Warranty
  • Basic (duration)
    36 month
    Basic (distance)
    36,000 mile
  • Powertrain (duration)
    36 month
    Powertrain (distance)
    36,000 mile
  • Feature
  • Cruise Control
    Standard
    Tachometer
    Standard
  • Tilt Steering
    Standard
    Telescopic Steering Column
    Optional
  • Splash Guards
    Optional
    Power Windows
    Standard
  • Rear Window Defogger
    Standard
    Cargo Area Cover
    Optional
  • Removable Top
    Optional
  • Comfort
  • Air Conditioning
    Standard
  • Wheels and Tires
  • Alloy Wheels
    Standard
    Front Wheel Size (in)
    17 x 8.5
  • Rear Wheel Size (in)
    18 x 9.5
    Rear Tire Size
    P275/40ZR18
  • Tires
    245/45R17
    Front Tire Size
    P245/45ZR17
  • Pricing
  • MSRP
    $39,280 USD
    Dealer Invoice
    $34,370 USD
  • Engine
  • Displacement
    5.7L/346
    EPA Fuel Economy Est - City (MPG)
    17
  • SAE Net Torque @ RPM
    350 @ 4400
    SAE Net Horsepower @ RPM
    345 @ 5600
  • EPA Fuel Economy Est - Hwy (MPG)
    25
  • Fuel
  • Fuel System
    SFI
    Fuel Tank
    18.50 gallon
  • MPG (city)
    17 - 18 miles/gallon
    MPG (hwy)
    25 - 27 miles/gallon
  • Lighting
  • Fog Lights
    Optional
    Automatic Headlights
    Optiona
Vehicle Specifications​
year2000makeChevrolet
modelCorvettetrimSTD
style2-Door CoupetypeCoupe
sizeCompactcategorySports Car
made_inUnited Statesmade_in_cityBOWLING GREEN
doors2-Doorfuel_typeRegular Unleaded
fuel_capacity18.50 gallonscity_mileage17 - 18 miles/gallon
highway_mileage25 - 27 miles/gallonengine5.7-L V-8 OHV 16V
engine_size5.7engine_cylinders8
transmission6-Speed Manualtransmission_typeManual
transmission_speeds6-SpeeddrivetrainRear-Wheel Drive
anti_brake_system4-Wheel ABSsteering_typeRack & Pinion
curb_weight3246 poundsgross_vehicle_weight_rating
overall_height47.70 inchesoverall_length179.70 inches
overall_width73.60 incheswheelbase_length104.50 inches
standard_seating2invoice_price$34,370
delivery_chargesmanufacturer_suggested_retail_price$39,280
Equipment Details​
Chassis
Anti-Brake System4-Wheel ABS
Steering TypeR&P
Front Brake TypeDisc
Rear Brake TypeDisc
Front SuspensionIND
Rear SuspensionIND
Front Spring TypeLeaf
Rear Spring TypeLeaf
Tires245/45r17
Interior Dimensions
Front Headroom37.90 In.
Front Legroom42.70 In.
Front Shoulder Room55.30 In.
Front Hip Room54.20 In.
Exterior Dimensions & Weight
Curb Weight-automatic3246 Lbs
Curb Weight-manual3223 Lbs
Overall Length179.70 In.
Overall Width73.60 In.
Overall Height47.70 In.
Wheelbase104.50 In.
Ground Clearance3.70 In.
Track Front62.10 In.
Track Rear62.20 In.
Federal recalls for this 2000 C5
Recalls & Defects​
Recall Subject: Seat Belts:front
Report Receipt Date: 04/17/2000
NHTSA Campaign: 00v111000
Summary
Vehicle description: passenger vehicles. the lap belt webbing can twist allowing the webbing to become jammed in the retractor.
Consequence
When the belt webbing becomes jammed in the retractor, the seat belt may be unusable.
Remedy
Dealers will install inserts to the belt web guide of each lap belt retractor.
Notes
Owner notification began november 13, 2000.owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact chevrolet at 1-800-222-1020. also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
Recall Subject: Steering:column Locking:anti-Theft Device
Report Receipt Date: 02/09/2004
NHTSA Campaign: 04v060000
Summary
On certain passenger vehicles equipped with electronic column lock systems (ecl), when the ignition switch is turned to "lock," the ecl system prevents turning of the steering system. when the vehicle is started, the ecl unlocks the steering system. the vehicle is designed so that if the column fails to unlock when the vehicle is started and the customer tries to drive, the fuel supply will be shut off so that the vehicle cannot move when the vehicle cannot be steered. if voltage at the powertrain control module is low or interrupted, however, the fuel shut off may not occur and the vehicle can be accelerated while the steering system is locked. also when the control system shows that the ecl is unlocked and the vehicle is being driven, the lock pin location can vary. depending on the location of the lock plate relative to the switch transition point, there could then be contact between the lock plate and pin causing the steering to lock while driving .
Consequence
If this occurs, a crash could occur without warning.
Remedy
On vehicles equipped with an automatic transmission, the dealer will disable the steering column lock by removing the column lock plate. when the ignition key is removed, the transmission shifter will lock but the steering column will not lock. on vehicles equipped with a manual transmission, the dealer will reprogram the powertrain control module, perform a dimensional check of the column lock and, if necessary, replace the lock plate. the steering column on these vehicles will continue to lock when the key is removed. owner notification to owners of 1997 vehicles equipped with automatic transmissions began on april 26, 2004. owners of 1998 through 2004 vehicles (except 1997-1998 manual transmission vehicles) will be notified beginning on august 2, 2004. the remaining owners (1997-1998 manual transmission vehicles) will be notified later in 2004, when parts are available. owners should contact chevrolet at 1-800-630-2438.
Notes
Gm recall no. 04006.customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
Recall Subject: Exterior Lighting
Report Receipt Date: 04/07/2009
NHTSA Campaign: 09e012000
Summary
Sabersport is recalling 16,270 combination corner and bumper lamp assemblies of various part numbers sold for use as aftermarket equipment for various passenger vehicles. these headlamps fail to conform to the requirements of federal motor vehicle safety standard no. 108, "lamps, reflective devices, and associated equipment." these lamps do not contain the required amber side reflectors.
Consequence
Decreased lighting visibility may result in a vehicle crash.
Remedy
Sabersport will notify owners and offer a full refund for the noncompliant combination lamps. the safety recall began on may 11, 2009. owners may contact sabersport at 1-909-598-7589.
Notes
This recall only pertains to aftermarket replacement equipment and has no relation to any original equipment installed on vehicles produced by the vehicle manufacturer.in order to determine if your aftermarket lamp assembly is affected by this noncompliance, please review the list of model numbers provided to us by sabersport.the list can be found under "document search" located at the bottom of your screen.owners may also contact the national highway traffic safety administration's vehicle safety hotline at 1-888-327-4236 (tty 1-800-424-9153), or go to http://www.safercar.gov .
Recall Subject: Exterior Lighting:headlights
Report Receipt Date: 05/11/2009
NHTSA Campaign: 09e025000
Summary
Dope, inc. is recalling 42,540 combination corner and bumper lamp assemblies of various part numbers sold for use as aftermarket equipment for various passenger vehicles. these headlamps fail to conform to the requirements of federal motor vehicle safety standard no. 108, "lamps, reflective devices, and associated equipment." these lamps do not contain the required amber side reflectors.
Consequence
Stingray
To read the VIN number stamped on your car,
1st digit= Country of Origin (1 = US built)
2nd = Manufacturer (2 = General Motors)
3rd = Brand (1 = Chevrolet)
4th = Carline / series (Corvette)
5th = Type of Corvette (Combinations of engine, transmission and trim)
6th = Body style (2 = 2 door coupe, 3 = 2 door convertible)
7th = Restraint Code ( 2 = Active, manual restraint w/ driver & pass airbags)
8th = Engine type (G = LS1)
9th = Check digit
10th = Model year (Y = 2000)
11th = Plant (5 = Bowling Green)
Last 6 digits = Your car's actual number in the build sequence.
Some of the coding is likely to differ between US and European cars, for instance restraint system.
More detail of the meaning of individual characters on this link,
