What are the warning lights
Nigel curry
Hi all
Can anyone out there tell me what the warning lights are on the speedo face of my 1976 coupe please.(none of them light up) there are two and the top one is blue with the word bright!!
And the bottom one is green (I suspect maybe indicator shaped in a sort of long triangle)
Many thanks in anticipation
Nige
If the car still has the owner's manual, those should be shown there
I assume BRIGHT might mean the bright high beams of headlights
If its anything like my 1968 C3, then yes, BRIGHT is indeed illuminated when you have your main beam on (not illuminated in my photo below of speedo cluster).
The triangle ones are indeed the indicators. Speedo holds the left indicator, and rev counter holds right indicator. Also note in the photo below the illuminated BRAKE warning on the rev counter - means the handbrake is on.
(sadly, despite my awesome trip counter reading below, my C3 is not fitted with a big block)
