Right hand drive C5
We’ve had a few springs go on our Fords over the last couple of years. Yes, they certainly seem to be thinner these days. Got a set of mid year springs that I’ve had for 30+ years. They are heavy mothers.
Also the ends of the coils are cut off square rather than tapered just to save a few pence in the manufacturing process . That means the coil sits on a tiny point of contact in the strut mount causing a stress point in the last loop of the coil .
Here's a typical modern spring failure; it's off a Mercedes.....
Classic end coil failure due to over-stressing. the one on the left was about to go due to corrosion.
This is a spring from my '63 Daimler......
End coil properly closed and ground and the spring scragged during manufacture to obviate over-stressing.
It had been on my car for 50 years and after cleaning up and painting it went back on the car. It's still there. :)
( Apologies to the OP - this thread has wandered off subject )
On the subject of the RHD conversions to US vehicles Australia seemed to be the masters. Once they perfected the making of the RHD dashboards they were visually perfect.
Had a chance to buy a RHD mid year convertible ( a 64 from memory) back in the early 90’s. It was a nice car, but no power steering or brakes so I passed. Wasn’t too bothered about the brakes, but wanted the power steering.
I believe it’s still about.
Still got some pictures of it somewhere.
ZeroX
New user
Don't worry about going off topic, I have recently had some health problems that I need surgery for so I will be needing a lot of money for that, so finding a car has gone way down my priority list.
Thank you everyone for the help.
I have wondered whether an RHD conversion is really worthwhile - so I tried it on my C3.......
Surprisingly easy ! ;)
62 C1
While you are at it add in a rack and pinion and some electric power steering - off you go
robbiew
There was a right hand drive C5 in Sussex owned by a member called Max I think it's the one described
We all had a good nose round general feeling was the conversion was not great quality !
