Silverblack
Any advice on reducing cruising rpm. gearbox or diff best mods
That being the case I'm surprised those tyres fit under the arches tbh.275/75/15 is 31" diameter. Stock diameter of OEM fitted C3 tyre is generally 27". That size is going to make a significant effect on your gearing.
I'm with you on that one - presumably the 275 75 series tyre is on a stock 8" rim.....if so its tread width relative to height/aspect ratio will mean its probably 'skinny' enough in an old school way to fit 'in' the wheel well......just. If he is running a 3.08 diff....with thst tyre it must be equivalent to a 2.5 axle. It'll certainly be a bit sluggish off the line....That being the case I'm surprised those tyres fit under the arches tbh.![]()
| Net Brake Horsepower @ RPM: | 195 BHP @ 4000 RPM | 225 BHP @ 5200 RPM |
| Net Torque (lb/ft) @ RPM: | 285 lb/ft @ 3200 RPM 280 lb/ft @ 2400 RPM (Calif.) | 270 lb/ft @ 3600 RPM |
| Transmission Type: | 3 Speed Automatic Transmission L48 & L82 |
| Order Code: | MX1 |
| Type: | Automatic hydraulic torque converter with compound planetary gear system – three forward speeds and reverse. |
| Case Material: | Aluminum |
| Parking Lock Type: | P (Park)-R (Reverse)-N (Neutral)-D (Drive)-L2 (Low 2)-L1 (Low 1) |
| Selector Lever Location: | Center Floor Console |
| Lubricant | |
| – Type | Dexron II (at time of release. Dexron III may also be used.) |
| – Capacity | 20 Pints (Dry) / 8 Pints (Refill) |
| Clutches | |
| – Type: | Four, multiple disk |
| – Material: | Steel with bonded organic facings (Drive Plates) / Flat Steel (Driven Plates) |
| – Forward Clutch: | 5 each – Drive and Driven Plates |
| – Direct Clutch: | 4 each – Drive and Driven Plates |
| – Intermediate Clutch: | 3 each – Drive and Driven Plates |
| – Low & Reverse Clutch: | 5 each – Drive and Driven Plates |
| – Release Spring | Radial row steel coil |
| Planetary Gear Set | |
| – Reaction Carrier Assembly: | 4 Steel Pinion: gears |
– Output Carrier Assembly:: | 4 Steel Pinion: gears |
– Intermediate Band: | Circular Steel with Organic Lining |
Range / Gear Ratios: | |
– D (Drive) | 2.52:1 (first gear) – 1.52:1 (second gear) – 1.00:1 (third gear) |
| – L2 (Low Two): | 2.52:1 (first gear) – 1.52:1 (second gear) |
| – L1 (Low One): | 2.52:1 (first gear) |
– R (Reverse): | 1.93:1 |
| Rim Size: | 15 x 8.00 |
| Stock Size and Ply Rating: | P225/70R15 |
| Tires (Optional) | |
| – Construction: | Aramid fabric belted radial |
| – Size: | P255/60R15 |
Defo got a tacho problem if reading 6000rpm at 60 mph . If you were really running regulary at 6000 rpm you would have pistons coming through the hood by now ! Presumably your engine doesn`t sound like it is running at 6000 rpm ? You will have a TH350 in your car if it`s a 3 speed auto .Wow thanks lads great info,
Ive got the diff off at moment,got some grinding noise when warmed up!!!. My taco must be reading wrong cos at 60 I'm showing 6000 rpm.
I think my gearbox is a th350 also.
