V8Adam
Busy user
Hi everybody,
I have an odd factory alarm issue that has popped up on my 1981 Corvette. The issue is that when the factory alarm system is armed and I unlock the drivers door with the key, the alarm goes off. If I unlock the passenger door first, it does not go off. If I turn the key counter clockwise in the drivers lock first, it does not go off. If I turn the key counter clockwise in the drivers door, it shuts the alarm off.
There is a post in this forum that indicates that this is normal behaviour with user dskopp stating 'Deactivation occurs when you use the key and turn it counter-clockwise first, then clockwise to open the door' but I do not believe this is normal behaviour. Both the owners manual and factory manual simply state that unlocking the door with the key will disarm it.
I did change the t-top mount plates before this issue occurred. After I did this I would lock the car (arming the alarm) and as soon as I shut the door, the alarm would go off after a couple of seconds. I then realised that the new plates were slightly different and the t-top pins were not pushing the switches to the open position. I therefore tried disconnecting them but the issue then changed to what I now have. I then reconnected them but used a zip tie to keep the switches in the open position, again issue remained.
Any thoughts?
Any thoughts?
