It varies, anything above 20psi at hot idle is OK on an old engine, a rebuilt engine with a standard oil pump would be around 60 at cold idle dropping to approx 40 as the oil gets hotter.
At 70 it would always be a bit higher but again the amount will vary, assuming the gauge is working correctly of course
