Water should be boiling at 240 - if not boiling and a faulty reading could be the Water Temp Gauge with an earth issue - depending what you are running the Fans via the Temp Sender should cut in about 190 to keep the temp below the 200My c3 is a restomod,has a DeWitt's radiator with twin spall electric fans,,the temp gauge read 240 f the other day,,but it wasn't boiling over?,however I didn't hear the fans kicking in,,strange,,
Oooh ! an XJS Celebration , very nice . I had an XJS 3.6 manual in stage one tune circa 280 bhp . A joy to drive and sounded awesome on the over run .Thanks for that,,I've been trying to contact a auto electrician in Ripley I have used in the past when I had my xjs celebration.the guy mostly works on vintage/classic motors
A pressurised cooling system will boil at a higher temperature. 15psi is worth another 45 deg F.My c3 is a restomod,has a DeWitt's radiator with twin spall electric fans,,the temp gauge read 240 f the other day,,but it wasn't boiling over?,however I didn't hear the fans kicking in,,strange,,
The silky smooth Jaguar V12 is a work of engineering excellence in my book . I had an XKR too and as you say , the values of good condition low mileage Jags has really shot up . If only we knew !Great cars had a few xj6 first was a 71 4.2,,wish still had it,,had a V12, 5.3 xjs too,mpg no better than the corvette,you needed a petrol tanker to follow you,lol,sold my celebration just before prices skyrocketed,,but you win some lose some
Good point - Budgie do you have a sealed system with an expansion tank, or a non sealed system with an overflow pipe allowing for expansion loss, also check the wiring to the sender unit?A pressurised cooling system will boil at a higher temperature. 15psi is worth another 45 deg F.
