I thought it risks over heating the auto trans doing that .The only time I regularly stick an auto in low gear is going down hills. I’m still of the save the brakes mentality.
I am up and down from 3rd ( Drive) to 2nd as a matter of routine . Gives sharper acceleration and better throttle control when cornering . I have an Edelbrock Torker 2 single plain manifold so it thrives on keeping the revs up . Hardley ever manualy select 1st though as don`t like scream the revs to the red zone .I've recently had a couple of interesting conversations with C3 owners who amazed me when they said they never use 1st & 2nd and just use the Drive / 3rd on their automatics.
It has me wondering why and do many owners only use the 3rd / Drive option?![]()
Maybe if you’re coming down some pass in Colorado but in Worcestershire it’s not something you do for very long. Better than cooking the brakes.I thought it risks over heating the auto trans doing that .![]()
Interesting, I never knew that, thank you.Problem with always just putting it in drive is the auto tranny has its own controller, today it has over 4 meg bytes of calibration control
IF never using other gears then the TCM (controller) learns the driver's style and adjust just for that style
That means that if seldom manually shifting the TCM has not learned that and the car is a pig when it needs more output
Just thinking about what’s been said about using 1st & 2nd gears on old style and now ancient auto gearboxes as in the C3, will it be good for the box to be used in that way on a regular basis?
I just don't see the logic in shifting an 'old school' auto box manually - if 100% stock and without a shift kit etc it'll change slower than leaving it to its own devices.Just thinking about what’s been said about using 1st & 2nd gears on old style and now ancient auto gearboxes as in the C3, will it be good for the box to be used in that way on a regular basis?
Obviously I'm not yet an owner, but I would assume to allow you to a) Have that manual control and b) To pull harder through the revs (within tolerance) than the auto would?I just don't see the logic in shifting an 'old school' auto box manually - if 100% stock and without a shift kit etc it'll change slower than leaving it to its own devices.
That’s my way of thinking also. What’s the point?I just don't see the logic in shifting an 'old school' auto box manually - if 100% stock and without a shift kit etc it'll change slower than leaving it to its own devices.
Having lived with an A8 and driven it in all modes I'd say that's a highly dubious generalisation. If you've been driving around gently in Tour mode in D and jump on the throttle the transmission immediately knows the car is being asked to do more work and reacts accordingly. It'll stick itself in a higher performance mode until it decides the driver has settled down again. And the paddles don't seem do anything that can't be achieved with the throttle pedal in terms of driving mode.Here is an example of a C7 with auto tranny as the engine and tranny being controlled as how much torque is allowed, and when
Here is just one of the several torque tables in the tune, as you see depending on the RPM how much torque the TCM will allow as output
As you see if using D only and that also means lower RPMS then less torque will be allowed so good reason to downshift,
raise the load, torques up the drivetrain and allow as much as 100 ft/lbs more torque
Consider if driving up hill and having to push the mass yet TCM only allowing 2/3rds of the torque, add setting the Corvette into touring mode
and it's a slug in D only
Reason Corvette has had auto tranny paddle shifters as even GM knows using D only sucks and is boring
