phil_bennett
I've been mulling over how to handle this situation for a while now. Was due to attend the Yorkshire Supercar & Superhero day back in September and after getting car out for a polish realised the brake pedal had gone soft with no travel. I checked the fluid levels which were low, so it needs brake fluid flush and bleed. Can't see any obvious leaks around the master cylinder or dripping on the garage floor. So looking at the master cylinder I wonder if the seal is a bit perished and the fluid has just leaked out.
I'll attach some pictures, but just after some thoughts really. I'm not competent enough to rebuild or replace. The plan would be to get a new master cylinder from Scott, find suitable garage that would do the work, then get RAC out to then transport this to the garage.
Does this look like a master cylinder which has been leaked on and needs replacing?
