The clutch on my ‘75 starts to engage when the pedal is only very slightly lifted off full depression.
I’m interested to know if this is the same on other C3s or if your biting point is higher on the pedal travel?
My linkage is correctly adjusted to give just a little free play. The car is fine to drive generally, I can’t detect any clutch drag, but sometimes it can be difficult to get reverse. The other thing is, and this is why I’m questioning the clutch set-up, is that I have now got a pretty shot synchro on 2nd gear after only a few thousand miles since a previous rebuild. Low road speed and engine rpm changes into 2nd gear are fine but if I gun it in 1st, the change into 2nd is getting really difficult (ie likely to crunch) I’m wondering if the clutch set- up could have contributed to the synchro failure. It could just be due to an inferior quality synchro ring and nothing to do with the clutch, but I don’t want to destroy another synchro after I’ve got the gearbox rebuilt again. Changes into 3rd and 4th are fine. The clutch is a RAM HDX performance, gearbox is Borg & Warner.
