I would only use an Optima Red Top (AGM Absorbent Glass Mat Battery) there are others from Tanya Batteries, with a CTEK MXS 5.0 T UK Battery Charger
This is a Gel Battery with no acid to leak on the engine computer (PCM/ECM) and critical wiring harnesses below the Battery tray.
I have just moved house and after 15 years’ service from my Optima Red Top Battery and CTEK MXS 5.0 T UK Battery Charger I noticed a white spot on my garage floor I was getting an acid type leak from the negative battery post and casing, very strange, it did take a very little patch of paint off the chassis.
I replaced the battery, and still keep the old battery fully charged to use for pumping up my car and bicycle tyres, the negative post still producers the odd small tear drop of fluid.
Michael.
