trevbeadle
Hi,
had a look from under the front of the car and noted that there seems to be no 'seal' between the sides and top of the radiator and the plastic ducting ( see pics).
Is this by design or is something missing? I remember the importance of good sealing of the C3 rad to stop airflow from bypassing the radiator core. If missing I can probably fashion something from high-density foam or are there part numbers?
Also the chin spoiler, it seems loose.......should there be 'springs' or similar to return it to the correct angle after grounding on low road surfaces?
