Do not recall any TSB or GM recall as to LS1 using a lot of oil
Steering wheel, options look at the RPO codes listed under door of glove box
NK4 Steering Wheel, Sport Leather
NP7 Steering Column, EEC Approved
NT3 Emission System EEC 00
N37 Steering Column, Tilt, Telescoping
2001 Corvette Specifications Major Changes for 2001
Two new exterior colors:
Quicksilver and Speedway White
INCREASED Horsepower- 350HP
JL4 Active Handling Generation II-Standard Safety Feature. All models- Chrome Exhaust
Tips Stainless Steel and Aluminum Exhaust.
RPO - ZO6 Option
Model Availability Standard Safety Features
Coupe 1YY07JL4 Active Handling Generation II
* Convertible 1YY67Air Bags - Driver and Passenger
Hardtop 1YY37Brakes - Power Disk, 4 Wheel
Anti-Lock
Assembly Plant Daytime Running Lamps
Bowling Green, KY Remote Keyless Entry - with Active Halo Lighting
Side Guard Door Beams
Select Standard Features Starter Saver and Battery Saver
Mechanical Theft Deterrent System - PASS-Key
Engine - 5.7L V8 LS1Select Optional Features
Transmission - 4 Speed Automatic w/overdrive (Coupe & Convertible) Six Speed manual (Hardtop)Electrochromic
Mirrors*
Traction ControlAxle Ratio - Performance
Steering - Speed sensitive, power rack and pinion Compact
Disc Changer - Remote, 12 Disk
Suspension - Z51 Sport suspension (Std. On Hardtop)Electronic Dual Zone Climate Control
Interior Floor Mats
Air Conditioning Fog Lamps
Defogger - Rear Window Head-Up Display
Gauges - Analog, Ultraviolet Floodlit Luggage Shade & Parcel Net (Coupe)
Grab Handle - Passenger's side Memory Package - Exterior mirrors, radio, driver's seat, climate
Ignition - Dash Mounted control & Power Telescoping steering column (if so equipped)
Locks - PowerMoldings - Body Side
Radios - Delco cassette w/Bose speakers (coupe & Power Telescoping/Manual Tilt Steering Wheel
convertible)Radio - Delco CD w/Bose Speakers
Radios - Delco cassette (hardtop)Roof Panel - Removable,
Blue Tint (coupe)
Seats - Leather TrimmedRoof Panels - Dual Removable (coupe)
Seats - Power driver's side (coupe and convertible)Seats - Power Passenger - Sport
Exterior Selective Real Time Damping (adjustable shocks)
Removable Top - Body Color (coupe)Transmission - 6 Speed manual transmission
Tires - Extended mobility w/tire pressure sensor Twilight
Sentinel w/Automatic Headlamps
Wheels - Forged Aluminum five spoke Wheels-High Polish or Magnesium
Windows - Power, driver and passenger express down Z51
Performance Handling Package (Standard on hardtop)
2001 Technical Specifications –
Dimension (In.)
Exterior Coupe-ConvertibleEngine
Wheel Base - 104.5 Engine Code LSI
Length - 179.7 Description 5.7L (346 CID) V8
Width - 73.6 Compression Ratio 10.1:1
Height - 47.7Horsepower @ RPM - 350 @ 5600*
Track, Front - 62.0Torque (lbs. ft.) 350 @4400
Track, Rear - 62.1Exhaust System - Full Dual, Aluminum stainless Steel
Interior Tires / Wheels Passenger Volume (cu. ft.) - 51.4 Tires Std. (Front) - P245/45ZR17 Extended Mobility
Passenger Capacity - 2 Tires Std. (Rear) - P275/40ZR18
Extended Mobility
Headroom, Front (in.) - 37.9 / 37.6Wheels Std (Front) 17" x 8.5" Forged Aluminum
Leg Room, Front (in.) - 42.7Wheels Std (Rear) 18" x 9.5"
Shoulder Room, Front (in.) 55.3
Luggage Compartment Trailer Towing
Trunk Volume (cu. ft.) - 24.9 / 13.9 (top up)Towing Class - Not Recommended
Liftover Height (in.) - 36.7
2001 Corvette Colors
With Suggested Interior Combinations
Exterior Interior (Leather Trimmed)
Black Light Gray Torch RedLight Oak
11 - Lt. Pewter MT...
12 - Quicksilver MT*...
28 - Navy Blue MT..
40 Speedway White *....
41 - Black....
70 - Torch Red....
79 - Millennium Yellow.
86 - Magnetic Red II.. .
91 - Dark Bowling Green MT.. .
Brakes
Type, Front - Hydraulic Power Disc (dual Piston)
Type, Rear - Hydraulic Power Disc
ABS - 4 Wheel
Lining Material, Front - Semi-Metallic
Lining Material, Rear - Semi-Metallic
Swept Area, Front / Rear (sq. in.) - 263.0 / 158.8
Capacities
Cooling System (qts.) - 11.4
Fuel Tank (gals.) - 19.1
Base Curb Wt. (lbs.) - 3,221
Restraint Systems
Air Bag - Left Standard Right Standard
Front Belts - Left 3pt Lap/Shoulder, Right 3pt
Lap/Shoulder
Steering and Suspension
Steering Type / Ratio Magnasteer II speed sensitive,
Power-Assisted, Magnetic Variable Effort / 16.1:1
Front Suspension - Short/Long Arm Double Wishbone
Rear Suspension - Short/Long Arm Double Wishbone
Front Stabilizer Bar (mm) - B/F45 23x3.8 Z51 25.4x4
Rear Stabilizer Bar (mm) - B/F45 19.1x2 Z51
21.7x3MT - Indicates Metallic Paint
Convertible Tops are Available in White, Black and Light Oak
.Hardtop Available with Black Interior Only, Not Available with Quicksilver, Navy Blue, Magnetic Red,
Millennium Yellow, or Dark Bowling Green Exterior.
.Magnetic Red and Millennium Yellow are extra cost premium colors
.All paints use Base Coat / Clear Coat System which is formulated to minimize the effects of acid rain, water
spotting, and other environmental damage.
.Some Color/Trim/Model restrictions apply; Contact your local Chevrolet Dealer for Details.
* New or Changes for 2001
**Information from the 2001 GM Product Preview Fleet and Commercial
Vehicle Guide
*** 2001 availability will be two basic packages above the already standard 1SA package.
The 1SB option package which is the standard equipment package and adds to it, the memory system (power seats,
sports bucket seats, dual zone air), fog lamps and the rear luggage shade.
The 1SC package includes all the above plus electrochromic mirrors (new for 01), HUD, twilight sentinel and power telescoping steering column.
The Convertible packaging is slightly different in that the 1SB package includes the electrochromic mirrors
