Cam swap
Hi guys, just wondering if anyone near Essex area is good with doing cam swap on a ls2 c6?
thank you
Just keep in mind when changing the CAM grind specs that effects vacuum which then that confuses the PCM (engine controller) so have set up with someone in advance to do the PCM tuning to make all the calibration changes at that time, else with stock tune the engine will not function very well.
