You don't need the wiper door (or headlamp doors for that matter) - why not plug the vacuum sources that feed them - simply take them out of the equation while your are sorting the carb. Perhaps consider sourcing a complete quality carb rebuild kit and respective base gasket IF the carb has been sitting dry for any length of time. I've been faffing around with yank motors for nearly 50 years and the very first things I would do with a newly bought car (if the service history was dubious) was - carb rebuild kit. New oil and filter. New dizzy cap, rotor arm and points. New plugs and HT leads. Set-up timing. New thermostat (and as neeeded, antifreeze and fan belts). One simply couldn't rely on previous owners maintenance schedule (if any). Some of the above you can discount........but not the carb rebuild. Its not a difficult job.........or borrow a 'known' working carb from a friend........simply take the carb out of the equation.The wiper door just opens and closes on start up. Been chasing it for a while, but you get fed up upside down under the dash not achieving anything. My friends got a smoke machine but we did do the rear mains crankshaft oil seal in the spring which was a priority so maybe cure the door leak over winter. Thought the door vac button thing under the grill I changed would sort it but will have to chase elsewhere. I did find one aperture not plugged that was a while ago and sorted that. I'm with you Tim on a vac leak throwing the idle out. I was going to get the feeler gauges out to let you know how much the blades are open but then remembered its cylindrical chambers so no hope. On the positive side I've got no dieseling on shut down that was an intermittent problem. I've got a barely used gasket so will swop that as that could be a possible leak as it's been on and off a few times for various things while I've had it. I'm going to wind the sec throttle stop in half a turn while I got the carb off again. I got a few I guys local I know if I run into a brick wall but it's always more satisfying fixing it yourself and learning the process.
