A couple of weeks ago my good friend Mark Eaton and I took a ride out to Mill Lane Speedshop, near Finchingfield in Essex to put my Corvette through its paces on their rolling road dyno.
I put the engine together a few years ago, it drives really well but I always had it in mind that I should get it on a rolling road to check the carb is jetted correctly, and of course to see what the car is putting out - torque and power.
The engine is a stroked small block 383, AFR heads, Magnum 270H cam, 600cfm Holley double pumper, Weiand dual plane intake, Flowtech headers. I spec’d the build primarily for strong mid-range torque. It’s a 4 speed manual with a leggy 3.08:1 diff that I put in to make the revs lower for normal driving - buts that’s why I needed good torque from the engine to turn that diff ratio.
Heres what we got:
The air/ fuel ratio was spot on. The plot shows it goes rich when the throttle is first applied as the pump shot goes through the carb but then it stays right where it should through the rev range. No alterations to the jetting required.
The power figure was a surprise - much lower than I was expecting - the best pull gave 260 bhp at the wheels. I had in mind that my engine was in the region of 380 at the flywheel, so was thinking that would equate to well over 300 at the wheels. Losses from the ancillaries and drivetrain could be much more than I thought but it looks like the engine doesn’t have the bhp I thought either. I read somewhere a dyno test is also known as a dream crusher! Mark was doing his best to console me! It actually got worse, further pulls were in the 245 region due to the engine getting hotter. Best power was at the first pull with the engine temp at around 160F.
What it does have though is a good torque curve through the rev range, particularly at mid revs. This is what makes this car a quick street car - it pulls hard in any gear even from low revs. Power drops off at 5500rpm
The guys at the Speedshop suggested a dyno test and coffee morning which is something Mark and I will organise if there’s enough interest.
Heres what we got:
