EFI experience and anyone tried a 6-speed or more automatic gearbox?
alexsalvaris
Hi all,
Was looking to see if anyone had any experience of swapping their carburettor set up to an EFI unit, and/or anyone tried to fit a "more than 4 speed" automatic transmission.
For reference, I have a 383 stroker engine with a Holley Street Avenger 670cfm carb. Should be good for c.450bhp and about 450 ft/lbs or 600Nm. I have not dyno tested however.
I have looked at the Edelbrock Pro-Flo 4 rather than the more popular Holley Sniper 2. The Edelbrock has a fuel injector in each runner of the intake manifold, which makes it a more true EFI unit than the Holley. I think! Anyone have experience of using either EFI system and what's your take on it? Not looking for more performance, just better and more linear power delivery throughout the rev range.
The transmission might be more challenging. I have a 700r4 and would like some more gears for better acceleration and keeping the engine in a better power range. I enjoy taking my C3 around a racing circuit. I have seen some builds using an automatic GM6L80 transmission. Anyone have experience with these or ZF 8 speeds?
Thanks,
Alex
Quote
end quote
You are so right about multi-port injection. Why spend £1000 to perhaps £1500 for a fuel injection system like most that are effectively an electronic carb......this is what OEM car makers were fitting to American cars in the early/late 80's.
For perhaps double the cost of one of these above Edelbrocks Pro Flo 4 will give you individual port injection, a new inlet manifold, system specific distributor and dash mounted tablet to set it-up and display all sorts of parameters on.
All you need in addition is to fit a high pressure fuel pump in your tank (or a new tank with pump) or their fuel 'sump' in the engine bay.
Good deal I'd say..........but, my major concern would be if one ran-in to technical problems. All you will have is Edelbrocks dedicated on-line forum to ask questions and (hopefully) answers one can understand.
Take a few minutes to go on the forum and try to understand some of the silly problems (and non-conclusive OEM responses) that purchasers come-up with.......often bizarre. It seems to me that whilst it all appears relatively easy to install and set-up.....here in the UK we would almost be on our own........unless perhaps you have a third party install it. This (to me anyway) defeats the object of a reasonably priced product.
I have researched the FI issue for a number of years now (having had a earlier desire to install an old school 8 stack system to my stroker big block) and have come to the conclusion the old school methods (carbs) may not be as bad as we think. You won't get any additional power from fuel injection - better fueling and economy (relatively) perhaps, smoother running (perhaps)........but unless you travel many miles, fully understand how the systems work/or have a tame mechanic its going to cost you a comparatively huge sum of money for little return.
Multi speed transmissions - I think your current transmission probably has the ideal ratios plus a useful overdrive ratio to cover all type of use.
Modern 6, 8 and 10 speed transmissions whether manual or automatic are designed for todays computer controlled vehicles and maximum economy/minimal emission figures. Your 383 stroker engine has more than enough torque to obliviate the need for a multi ratio transmission and operate over a far wider rev band without the need for multiple ratio that a smaller capacity engine would need.
Most of the 6 speed aftermarket manual transmissions have gear ratios spaced once again for 'todays' economy/emissions orientated usage in computer controlled vehicles, and not always for performance use. You'll need to look very carefully at manufacturers spec's to find 'true' performance ratios on modern gearboxes.
I too have been wanting to put the Pro-Flo 4 setup on my 1968 327 - like you said, it has multi-port injection and so forth. Looked into it a lot.
The reality is though is that it costs a lot of money and I hardly drive my C3 that much. So as much as I would like a nice smooth setup of fuel injection and better economy, I can't really justify it as a priority for the mileage I do in my C3. I mean I've had the car 9 years and I've only done about 3.5 - 4k miles in it.
And btw
Capt' - I've had my '68 for 25 years and have done a similar mileage as you (max) and it ain't gonna increase too much in future.......so spending out perhaps £3.5K or more for FI just dosen't make any sense (and much the same with a 5 or 6 speed transmission)
And btw
Wowzers, and I thought my mileage was bad in 9 years :ROFLMAO:.
Out of interest, why did you go for the big powerful engine (over the original 427) and not drive it much?
As for 5 speed and FI and a 383 stroker - I'd love all in my C3, but I just can't financially justify any of it. I mean I battled with myself for a long time about getting electric headlights / wiper doors over the cost and the fact I pretty much never drive at night, and try to avoid driving in the rain :ROFLMAO:. But then that outlay I ultimately justified because I wanted to fix my slow vacuum issues and slow wipers, and mostly I just wanted to challenge myself in fitting all that stuff to the car (I'm a noob when it comes to mechanics). I learnt a lot doing that.
The reason why Capt? - I have always loved the concept and fun of cars with excess cubic inches and loads of power without any for of electronic interaction. All these Supercars out there withan advertised zillion or so horse power........do you get to ever 'feel' all those zillions of supposed HP without electroic 'nannies' decided the tyres won't take it? - perhaps only at 'full chat' triple numbers speeds that you won't legally achieve on UK roads. My dream car would be an Edwardian open bodied race car with a huge capacity WW1 period aero engine.
Just love all the Ford 427, 428 and 429 powered cars of the 60's and early 70's.....and of course Mopar's equivalent and obviously GM's offerings.
50 or so years later so many aftermarket companies have honed and fine tuned all these engines significantly. For example the only item in my engine that is Chevy/GM is the engine block. Everything else is aftermarket......and arguably far better than GM's mass production items.
My goal was to equal or exceed the performance of GM's L88 power unit.....but in a street drivable way. Whereas the L88 engine is designed with a power band perhaps between 3500 - 7000 rpm mine is between 1800 and 6000 rpm and happy to cruise at 1400/1500 rpm with fuel consumption equal or better than a stock L36 427 (so 15/16 mpg on cruise)
As for not driving it much - other things (employment, family deaths, health issues etc etc) have simply 'got in the way' over the years. And of course we now have the spectre of Khan's London with its cycle routes, Uber drivers, many other road changes deliberately designed to catch-out the unweary and generate income for local authorities and Khan's TFL. I'll stop here or it'll turn in to a rant
Quote
end quote
Hi Alex
Have you considered changing the differential ratio? Im not too sure what ratio you might have at the moment but I think the later C3s were geared more as cruisers regarding the final ratio.
Re the EFI, I know two people that fitted it and they are really happy with it. The background was that they were both totally fed up with trying to get their previous carburettor to work properly (probably something wrong with the carb in each case) so were faced with either buying a new carb or trying the EFI. Both did have fun and games trying to get the EFI to work properly and one of these guys is an electrician and very good with cars!
EFI isn’t going to be much better than a good carb - yours looks relatively new and is the right size.
I very much agree, just don't have the finances for such fun. Closest I got was a 205 GTi with a tuned throttle bodied 306 GTi6 engine in it. Granted all electronic fuel injection etc, but still very fun having a car with much more power in it than it was designed for.
And yes, I love the old cars for that sense of speed at legal speeds. Like you said, fancy supercars are wasted most of the time as they are barely idling on public roads.
And oh yes, an aero engined car. Now we're talking :cool:
alexsalvaris
Thanks all for the replies. I will look into the differential ratio, though I'll be honest cruising at 70mph on a motorway, I wouldn't want the revs any higher.
The car feels great driving around Snetterton on a track day and it sounded amazing. I agree compared to a Porsche Cayman you feel much more engaged driving around. This makes it a very raw feel.
As for the £s spent, for the amount this car is driven, it makes no financial sense for the amount spent and to be spent. It does put a great big smile on my face and many others when they see it, and that makes it worth it.
Good to hear the Edelbrock EFI has good feedback, I will look into it a bit further. As for the transmission, unless someone has a good experience with a 6-speed or more for a C3, I'll stick with the 700R4 for now.
Alex
Whilst the Edelbrock system may well be appear to be the best of the user installed, self tuning products out there on the market - my worry would still be the seeming lack of any physical tech back-up here in the UK should issues occur.
Even the supposedly simple throttle body Fitech and similar types of product seem to turn-up for sale regularly, seemingly with little or no useage? - there must be a reason for this? And why on the largest USA Corvette forum does no one seem to use the Edelbrock product?
Alex
The 70mph cruising revs is the compromise point when you ”only” have four gears and whether you want to give up a bit of cruising comfort to gain acceleration in the gears.
70 in my car it’s 2650rpm which I can live with. I’m guessing your rpm at 70 is quite a bit lower than that?
Alex
IF not knowing what diff gear is installed to be able to decide on installing a different ratio, do this
Do a Driveshaft Turn Test.
Before you can begin identifying the gear ratio, you will also need to know if the rear end is a “posi” or open differential.
This is required because identifying gear ratios is a little different for each unit.
To begin with, raise the rear of the car with a floor jack and place a good set of jack stands under the car on the frame or rear-axle housing.
Once supported, place the transmission in Neutral and turn one of the rear wheels.
  • If the opposing wheel spins in the same direction, you have a posi or limited-slip differential.
    If this is the case, you can leave both jack stands under the car.
  • If you spin one of the rear wheels and the other one rotates in the opposite direction, you have an open differential.
    In this case, you will need to remove one of the jack stands and put one tire back on the ground.
  • While doing this test, some guys like to use soapstone, chalk, or tape to put a mark on the tire and driveshaft to make counting the total revolutions easier. If you also want to do that, a modeler’s paint marker also works well. I typically focus on an already supplied marking of some sort on the tire (like a certain letter of the tire’s name) and one of the universal joint bolts and use those as your reference. If using a paint marker, make a large, visible dot on both the inside of the tire and on the driveshaft.
    (we used tape)
  • When you have your marks applied, if the car has a posi unit, both tires will be in the air.
    Rotate the marked tire one revolution while counting how many times the driveshaft rotates.
  • eg, If your driveshaft made 3 3/4 revolutions, that would determine a 3.73 gear ratio.
    If you get approximately 2 3/4 revolutions, you have a 2.76 gear ratio.
  • Like previously mentioned, if your car has an open differential (non-positraction), you will want to perform the check with one rear wheel on the ground. Again, mark the inside of the tire and a spot on the driveshaft with your paint marker. Now, rotate the suspended tire two revolutions and count the number of driveshaft turns. The reason to make two revolutions is the open differential actually rotates half as many times as a ‘posi,’ because of the design of the “open” gear operation.
  • if the driveshaft turned 3 3/4 revolutions for two rotations of the tire, you have a 3.73 gear. A driveshaft that rotates 2 3/4 times announces a 2.76 gear ratio.
monkaw14
Sometimes after a busy day in Australia, I relax playing on this site called - Red Stag Casino. The slots there are fun and the site is very easy. I don’t put too much time, just a little here and there, and it gives me a smile. Maybe it can do the same for others too. Best wishes and take care. Bye.
TY for info!
