I'm experiencing some electrical issues. I've had the ignition switch changed few months back after getting "charging circuit fault" messages on starting. (its contacts where quite burnt) I put a new red top battery on in April this year and I've had most of the earthing points cleaned up.
So after all that everything was fine for a couple of months until yesterday when I came to start the car. (It's been on a good quality tender but not started for about 4 weeks). It tried to turn over very slowly and then died, after that just the clicking noise. I tested the battery and it was around 11v, (odd as it has been on a tender) so I took it off and put back on the original yellow top which I still had. that one did barely start the car and after which it ran fine, the alternator was working and charging because the dash voltage went up to 13ish volts. I've got that yellow top battery on charge now also disconnected from the car and so I'm expecting it to be ok for testing again later.
My question though is related to a difference in the actual battery voltage and what the dash shows with the ignition on. Should there be a variance?
I'm guessing my next quest should be to find out if I have battery drain of some kind. New multimeter on order.
