The rest of my bits have now landed and cleared customs and I'm going to collect them next Tuesday, so I decided that it was time to start removing my existing exhaust. The pipes and mufflers all came off pretty easily, probably because the previous owner had renewed them and I had removed them whilst renovating the car. The cast iron manifolds were a bit more tricky. I had heard stories of manifold bolts snapping trying to get them off. This wasn't an issue though, they were all very tight but came off in one piece. The trouble was getting at them. The long stud which goes through the A/C compressor needed a very thin wall and very deep socket, I had one which was thin enough but not long enough. The end of the stud stuck out of the end of the socket, so no way to get a ratchet on it. In the end I managed to undo it with a pair of mole grips on the outside of the socket (very Bubba). At the other end of the passenger side the heater box prevented me getting a socket on at all, but luckily it came undone with a ring spanner and a long bit of tube.
What surprised me the most was the total lack of any gaskets between the manifolds and the heads. I take it this is not normal! I had always thought that the engine had never been touched as everything on it looked original, now I'm not so sure.
The good news it that now it's going to be very easy to replace my spark plugs and wires. I'll also need to give the engine a good clean up.
