First C3 Vette and luvin it :)
Waynio
Could be an aftermarket removable crossmember? I've seen them for sale online.
Maybe so, i just had a look and i see them aswell. Must of been out for a long time as this does look original. Just by the welds and the welding is crap on these cars and looks much the same as the reast of the car.
These cars maybe around 40 plus years old but by eck they were bad welders. I am no welder but i can weld better than them haha.
If i ever fully rebuild this in the future or maybe another ill redo them and add some of the mods they get. Its mad how they lasted this long, could be the lack of power they give out. Then though......the BBC Vettes had a little more power. Or did they weld better on them haha.
Waynio
Well its been a bad time in the family and this has been my needed break.
Not a great deal but feels like its getting there quick now. Still no rush but i think its going to get done before i need. well not need but expected so i mite slow it down a bit, as in do things that dont need doing now and was going to do over the summer.
As i have done the front end i wanted to get the rear brakes done, only the brakes as the rear suspension etc will be done next winter.
So sat the front end down on the stands and stood the rear end up on axle stands.
On removal the the discs i found a,,,,,,lets say modification. And with such bad taste. A section of a can of Carling. By eck the previous owner lives i Cider capital of the UK, down Cornwall Could of use a Scrumpy can lol.
I could not work out what the heck it was for or why it was fitted. Until researching to find out thats its a way to true up the discs. As these set ups are made with the discs rivetd to the hubs they are machined/trued up during manufacture. So on replacement of new ones they need the same doing.
For me though as the discs are in good order and its been like this for some years. i spoke to the previous owner and he did the fettle years ago.
The plan now is to just rebuild the calipers. fit the braided lines with new hard lines to the braded / hard lines.
The calipers now, i thought one side was seized as the pistons would not spring out. Then i stripped them down to find, one side had the modified O ring seals and one original lip seals.. And the lip sealed side had the springs fitted, where as the other side didnt. Although they dont need the springs fitting.
I have put in another order from Claremont Corvette for O ring seal kits.
This dam paint ont he calipers is darn good stuff as its being a reat sod to get off. Its taking a good amount of snad blasting, heat does not work much and i dont want to over heat the calipers either. Paint stripper it may be. I have run out of Nitromors so ill be getting more soon. .
Ill get to sorting them out later.
Bits of the engine next.
Waynio
I made up the rear lines from new braided flexi to calipers. Again with copper i had.
I have tried to clean back the calipers again to paint them but no luck, i need some decent paint stripper as heat and sand blasting is not doing it to well.
Also on removal and strip down of the rear calipers i notcied one side had old type Lip seal on the psitong, on the toher the uprated O ring seals. So today...or was it yesterday, i ordered another O ring set.
O ring
Lip/Umbrella seal.
i was going to make these tools, but the tenner each i didnt want to faff about making them
One is the oil primer and the other black threaded bar is to fit the Harmoinc balancer.
Got the gubbin needed. I got a cheap set of bolts, these will only be used for the Ancilleries though, not the heads etc 304 SS so i used thread lock and got some new RTV.
Join the dots and in a bit ill show how i timed it up.
Tool worked great. didnt snap, well if used correctly it shouldnt really.
Waynio
Good things and bad things, as always.
I have near finished the engine. All went well.
Except for the carburettor. I was rebuilding the 1975 Quadrajet carb and ordered the rebuild kit and a manual for helping to rebuild it and tune it etc. Only to find the carb i have is the worst of the Q Jets and even in the manual it says its better to buy another carb.
So in the end i got a new Edelbrock AVS2, with an adaptor though as the inlet manifold is a standard chevy. This gave it another .850 inch in hight so along with the aftermarket carb its going to be high, a sin sticking through the bonnet.
This is how set the valves up and timing.
Old school and i havnt done it for many years so lets see if it will work. More to it than levelling the valves mind you.
Then filled wkith oil and gave it a good prime. I was surprised and the torq the primer needed from the drill to do this. near burnt my bloody drill out.
New Fel Pro gasket, perfect fit.
And with this filter, which will not be used or the aftermarket filter will be a few inch to high.
I was going to make a bonnet scoop. and would of enjoyed that as i like messing with GRP.
Though i decided to just buy another inlet manifold and filter which should drop the set up low enough to have to use a scoop. Be a shame aswell to do it really. these cars have dam good lines .
Waynio
So to end that for now ill do some body body work while the parts arrive.
Not a great deal to do. I will be painting it this spring or summer so these are just touch ups.
Just paint damage
Bit of a gouge here.
This the worst spot. Looks like heat damage with the softness and delamination.
So i dug out the GRP gubbins i have. I have done a test spot to see if its any good, i cant remember how long i have had it.
A bit lumpy as i havnt mixed the filler in much. Ass aid just a tester.
I had to take te filler cap to the pait shop to get a match as they couldnt find it from the paint code.
View attachment 477194 471251346_10236200921108077_8305647736510393216_n.jpg
Waynio
Hope you all had a good one. Me i have been busy with a normal day trying to keep busy.. Fixed ( i hope T`s car ) crappy modern Merc that leaks haha.
Mine is so much closer to be done. To end the situation with the paint not coming off the rear calipers, i dropped one and snapped a bleeding bleed screw lol. no biggi, i found a used set on ebay and get a good pair for £40 to rebuild with the O ring conversion.
Quick sand blast then paint and done.
I fin a Dremmel good for cleaning the bores if needed. I use the polishing wheels you can get.
Just a quick whiz around is all that is needed.
Some folk say there springs are not needed but then some say they are. I decided to refit them.
A lot easier to fit the cylinders back in aswell towards the Umbrella/standard type. They just push in then a matetr to tap the dust cover in.
The front ones have been tapped in, dont need much.
And ding dong there we go. Tine to fit them now
Ah best fit eh pads, that would help. good how they used the same pads for front and rear. just smaller pistons used in the rear.
New copper lines made up, makes fitting easier. And cheaper than SS ones. A few quid.
Waynio
Got another job out the way, easiest yet.
It was the wobbly to the windows. I got these pads a few months ago and fitted them,
Just a bolt and catrefulyl sldie the old ones out
Not to easy to see the gap but there is a good few mm,
then tightened up
I sooo cant wait to clean it, dam manky or what.
Filled where need be and prepped for painting when i can
No rush for that to be done, got all i need though ready, 2k and 3k sand paper. paint and laquer. No primer though as i forgot. but then ill be painting it this summer so not bothered about a perfect finish. It will be taken back to GRP. Just hide the damage there si there for now will do.
That was Xmas day and Boxing day. So i chilled then for half hour.
Before i finished the polishing of the last weel, one job that i dont like doing.
Waynio
What a bleedin day. woke at 4am, could not sleep, got up at 5am, cant play out as to early. Neighbours put up with me enough as it is. So i tieded the shed a bit. THEN remebered i did have the gear box oil i need today. Or wire wool.. or locking washers. Nothing like unsorganisation hey haha
So went in for another brew. 8am came around and was out. getting DILLIGAF ready for engine to go in.
Lovely day for it aswell
This time i decided to remove the front wheel to aid getting it back in. It was a bit to tricky getting it out with the wheel on.
Ah the other night i fixed the firewall, i dont know why or how but a smallsh hole had delaminted, easy fix though.
T has noticed the electric bill going up a bit lol.
Bit of ally mesh and brigding filler. The paint i got is a good match aswell,
I have to appologise now but as i was so busy i didnt get many picks.
Had to shift the caravan again to make room. Cant wait now for the motorhome to be gone.
I fitted it all back as it came out, so engine and box. makes life easier. The clutch i am sure you all know how to do. I didnt get many pics but for the removal of the pilot bush.
I didnt have a bar or bolt for a good enough fit so i turned down one.
Only needed a mm taking off.
usual way, pack the hole with grease bit by bit and hammer the bolt in to hydraulicly push the bush out.
And out it popped.
then wack in the new one, well you know., and fit clutch.
was about thia time the rest of the engine bits arrived :) to tired already to bother to oprn it.
thinkign of it what else can i say or show to bget it in. bit of a faff to bet the enginemount bolts lined up but managed it after a few choice words and help of a cider or teo.
to tell the truth it was a pain in the ****. trying not to let the engine touch anything. being on paving flags makes it hard. Still its in and tomorrow ill put the inlet etc on.
I removed the rest of the electricery gubbins aswelll, just the Lamba sensor gadget that was fitted for tuning the carb.. Would of helped witht eh Q`jet carb but this new Edlebrock AVS2 is easy to set up.
Ok i hear a Vodka n coke calling me :)
Waynio
That's a good days work
Could of been a lot better really. I couldnt find the engine mount bolts. Had to go back to get some thread lock aswell. And got stuck under the car / engine hoist trying to line up the engine mount bolts haha. I need to be 16 again haha. all that faffing must of wasted atleast an hour. Still got stuff to do tomorrow like fit he rest of it.
I'm impressed what people with skills can do in the time allotted. For comparison, I like to tinker with my old cars, and over the weekend I spent a whole morning in my garage and effectively all I did was fit a bracket to my Corvette, and replace a side indicator on my FTO :ROFLMAO:. Its a shame no-one doing serious Corvette work like you lives nearby me as it'd be great to get better tinkering experience.
Keep up the good work :cool:
Waynio
Oh i have then days, make a big plan ( reason i dont do plans now ) then very little if anything gets done. Where are you anyway ?
As for today, taken it easy.
I am shattered today so not dome much but looking good if i say so my self. I got the gear selector rods connected up and the G box mounting bush done. Then i cracked on with assembling the rest of the engine.
This the inlet gaskets being flattened out, well i hope so as they arrived kinked. I knew i bought these steel billets for something.
A few people asked me why i made the car lift so high. I guess they dont work on cars as doing this did my head in. I am not 20 anynore and like my comfort when working on cars. not lying on my back. Still got it all done.
Just prep for fitting the inlet. bit of wire wool and spray penetrant then brake cleaner.
Waynio
And to continue it
this lot arrived as we know
New inlet/air filter, rocker covers. cheapo but better than the ones i sand blasted, and i am tart at times :)
Near fitted wrong carb gasket
so this one was fitted
Looking better now. Infact LUVIN IT :) :)
Again daft sod me didnt buy enough sets of rocker cover T bars and spreaders.
Once i fitted it i thought it looks a bit high, Very high so T came and gave me a hand to trial fit the bonnet. and it fits just nice.
So now its trying to work out what else i need. i have the fuel lines, well need a bit of 10mm to join to the main feed as its a bit short. Need to also work out what vaccum feed i need frot the inlet. Ill chill out tonigth and see whats what.
Oh yes and one other thing i didnt clean up was the fan
But 15 mins in the blaster and its ready for paint. MMmmm what colour to go for. Defo needed heat to get the bolts out. there were solid as expected really being steel into Aliminum
Waynio
So a question
The three outlets/inlets in the manifold near the thermostat. i know the one on the far left is for the heater core. What would i use the other three for. I am running straight carb.
The on thats at the back will be the one to the brake servo vaccum
MilkyNoSugar
Have you fired the engine up yet?
Apologies if I am telling you something you already know.
You may have read my Engine Issues thread. Having rebuilt the top end of the engine we fired it up for a few minutes, but clearly there was still something wrong and a new noise emerged as the engine started to warm up. We turned it off, checked a few bits and tried again, still the same so switched it off and pulled the engine out to send it to a specialist.
The new cam and followers are shot after no more than 10 mins running. The engine specialist said that as we had not been able to follow the correct start up procedure due to the con rod bearing failure, the cam and not been heat cycled and had worn prematurely. I think he said it should have been run with a high zinc based oil for 30 mins at 3500 rpm, then switched off to full cool down.
I would definitely make sure you know what the correct break in process is for the rebuilt engine before you fire it up.
Again, apologies if you know this already, but if I can save you knackering a brand new cam then it will be worth it.
