First C3 Vette and luvin it :)
If none of the lights are working it sounds like you have lost either the 12volt or the earth connection. Exactly which bulbs are not working? Have you just replaced the bulbs in the speedo and rev counter housing, or those in the centre console as well?
Waynio
Just had a mess more with it and this is what I am.getting.
Indicators, full beam and hand brake are fine.
The others. Speedo and tacho are near not working on ignition. Turn engine on amd rev it a bit and they get brighter. Not much though
Loose or bad connection maybe ?
does sound like a bad connection somewhere. Not likely to be the bulb holders, as they are all doing the same thing. Are the lights working okay in the centre console?
Waynio
Not working st all now j removed the console. On closer I section look like a ribbon may be damaged. May of been bad at first then on removal o made it worse.
No dash light works but as said before. No gauge lights now either.
Continuity test needed maybe.
Waynio
Thos the dash light dimmer switch is faulty. It flickers more i have been turning up and down.
Ill.remove it and investigate it.
Since your indicator lights are working, it's not a ground issue. Most likely a problem with the 12volt supply that comes from the light switch. Could be the Instrument lamps fuse, or a bad connection where the plug goes into the back of the speedo unit.
Here's the layout of the printed circuit
And the circuit diagram
Waynio
Defo found iys the switch/dimmer. Rehostat. More i turned it back and forth there a lot better now.
Seems full brightness now.
If i remove the switch can I get into the contacts to clean them up and contact spray them.
