FOR SALE.. 1997-2004 C5 Corvette Third Brake Light Pulser Kit £25
weslp00
    • "Delay-Repeat" Circuitry Provides Great Visual Display
    • Plug & Play Installation
  • No Adjustments Required
Your Corvette is low and not always seen by the driver behind you. This module can give you an extra measure of safety. These devices are full "Plug-N-Play" harnesses that simply plug into your existing center high mount brake light. There are no wires to cut and no adjustments to make. The module automatically pulses your third brake light when you apply the brakes. The light will pulsate on and off for about a second, then stay on steady for as long as you press the brake pedal. The unit is designed to create a gentle fluttering of light, so your car is more noticeable, yet it doesn't aggravate the driver behind you. The "Delay-Repeat" circuit means the brake lights have to be off for at least 15 seconds before the cycle can be restarted. So, if you are in bumper-to-bumper traffic, the brake light isn't always pulsing.
Fits all C5's..retail at about $75..
Can post or collection from Woodford Essex
07850990441
Stuart.
