theseoldcars
Greetings, all. I’ve got a shed full of C4 Corvette parts that I need to sell, so I thought I’d put them up here first for you all to have a gander at. Most of the parts are new but if there’s anything you have questions about, or you’d like to see – I can take pictures, if need be – then just drop me a direct message and I’ll get back to you as soon as I can.
I'll update this as items are sold (last updated 10/05) so if it's still up, it's probably still here.
DeWitts Pro-Series Radiator (32-1139084A): £750
New in box and for ’84-’89 models. This would set you back close to £1,100, so if you’ve wanted one for a while, or your C4 needs a new superb and upgraded radiator, now’s your chance to grab one at a bit of a discounted rate. This version has an integral transmission cooler, if needed, and also includes the custom mounting cushions – so it should all slip in and fit neatly. First-design AC condensers used on 1984 & early 1985 models will have to be upgraded to allow clearance for the thicker radiator, though, and do triple-check that it suits your application.
Details here: https://www.dewitts.com/collections/corvette-aluminum-radiators/products/1984-1989-aluminum-radiator
FlowKooler 1688 water pump: £80
New in box. This is a high-flow mechanical pump that serves up twice as much flow at low revs and idle. More vanes, tighter tolerances and a CNC-machined impeller all contribute to reductions in hot spots, cavitation at higher RPMs and lower operating temperatures. Anodised for a neat look. If you can get one, it’ll set you back around £180 at the moment, landed. As always, do triple-check it'll suit your application.
Additional details here: https://flowkoolerwaterpumps.com/products/1688-small-block-chevy-corvette-short-shaft-water-pump
Upper and lower radiator hoses, thermostat housing and thermostat: £30
This'll allow you overhaul your Corvette's cooling system in earnest; the part numbers, if you want to check them, are as follows:
Lower hose: ACDELCO 24226L
Upper hose: ACDELCO 26118X
Thermostat: ACDELCO 12TP1E (Believe I've some Stant alternatives, too, if you want a different temperature range: 45359 and 45358)
Thermostat housing: ACDELCO 1510175 (15-10175)
Let me know if you'd want to make an offer on individual items here.
Aluminium header tank: £80
This is for ’84-’89 C4s and ideal if your existing plastic tank is on its way out, or if you want something smarter and with a visible level gauge. In perfect condition, with cap – although it needs a relief hole drilling, or a different cap altogether, if I recall correctly.
Momo MOM-2702 steering wheel hub kit: £50
New in box and ideal if you want to fit an aftermarket wheel to your early C4 while retaining tilt and telescope functionality. Pretty sure this is only for ’84-’89 C4s, I think, despite what the listings might tell you.
Check out the customer images in this listing to see what it actually looks like: https://www.amazon.com/gp/product/B000GVHXXK/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Passenger-side flat dash panel and components: £50
Excellent condition used flat panel for the passenger side of ’84-’89 C4s. Includes the vent and ductwork. Ideal if you want to lose the breadbin and get a sleeker look.
Powerstop Z23 Evolution Sport carbon-fibre ceramic brake pads (front, set): £35
Set of performance front pads I picked up for my '89 and never used. New in box and ready to go. Part number is Z23412, so you can double-check its suitability for your application. Minimal dust with these, so ideal if you're tired of cleaning your wheels all the time. Would cost you about £60 landed, so a bit of a discount here.
Pair of used stock exhaust manifolds for an L98: £20
They’re making my shelf sag. Ideal if you want to freshen a pair up and then sling them on your car. AIR fittings are present and correct. Let me know if you need more details or pictures.
Complete AIR system: £40
Pulled this off my ’89. All in perfect working order. Ideal if you’re putting a C4 back together and want to restore the factory emissions system, or if the pump in yours is spent. Pump, original lines, hoses, canisters, etc. The whole lot.
eBay GT45 turbocharger: £100
New. You know the drill with these. Cheap but serviceable turbos that are ideal for low-buck projects. Unused and ready to waste a bottom end or two. Usually around £180.
Set of turbo SBC headers: £100
This is a single-turbo header kit that I was mulling about reworking to suit a C4. It’s new but will need some fettling, and it’ll certainly need work to fit into a C4. But it’s a good starting point or could be useful if you’ve something with a bigger bay and a wheezy SBC in it that needs a bit of a lift.
Give me a shout if anything is of interest and we’ll go from there! Sensible offers are welcome, especially if you’re going for multiple bits. I’ve probably got some C4-related shrapnel you can take away with you, too, if you come and collect – I'm located near Peterborough, for reference.
I am happy to post bits, too, but ideally the larger stuff would be couriered or collected. Anyway, just ask and we’ll see!
Have a great evening, all.
