Hi, some may have been following my thread where a bolt rattled out of (we think) my gearbox mainshaft bearing support. Collected all bits ready to strip out and send gearbox for a rebuild. The muncie re build kit came with new bearings but I also found an upgraded front bearing kit which comes with a sealed bearing, a steel spacer plate, two gaskets, new bolts for the bearing support and the correct french locking tabs to hopefully stop it coming loose again.
i have also bought a new bearing carrier in case old one is cracked or damaged.
Has anyone used this upgrade before which is supposed to stop potential oil leaks from this area which mine is suffering from. I am presuming the gaskets go either side of the steel plate between the bearing carrier and the gearbox casting.
Any thoughts or experiences appreciated.
