Hi, Please could you help me.
The rocker cover gaskets needed replacing. I changed the gasket on the drivers side, after which started the engine with no problem. Changing the gasket on the passengers side and in doing so had to push away the wiring harness that sits over the rocker cover ( some of those wires go to the injectors ). When I started the car fuel pulsed through the injectors as normal. When I restarted the car fuel poured through the injectors which remained open. Started car again fuel passed through as normal, problem seems to be intermitent. Do you think that by pushing away the wiring harness I may have broken a wire or one has come loose - I can't see anything obvious. Or is a coincidence that the ECM has packed in?
