Good evening all,
I'm after your experience and advice again.
New fuel pump arrived ( found that old one wasn't pumping enough fuel to carb - reason for not able to keep it running). I followed the correct procedure for taking the old one out ( inserting a longer bolt to hold rod back…) but what I didn't check was to see if the rod would move anyway.... And guess what?? It doesn't and is stuck, solid !!!
Have soaked it in carb cleaner, hand turned the engine to top position...and still can't get it out.
Have electric fuel pump on order - can I block it up and leave it in????
I don't have the expertise to take the front of the car off and it will have to be trailered to a garage....
Thank you for any help
