Hi all, out for a little run in the 72 this eve. Was running on side lights then it got to  dusk so raised the head lamps.
Stopped in a fuel station for some E5, I put the headlamp switch back to position one ( side lights) and fuelled up. I noticed the headlamps stayed up whilst engine was off and side lights were still on. Headlamps go down as normal when headlamp switch is pushed all the way in to βoffβ
Is this normal or another vac leak quirk ?
TiA
