althelodger
1978 Silver Anniversary:
Just to put things into perspective, I bought the car with one headlight out but the seller sold it with a conversion kit from sealed beam to conventional H4 and H1 bulbs.
When I checked the lights, there was indeed one light out when on main beam(only 3 lights on)
It appears that the outer lights are dipped beam and the inner ones are main beam-is this correct?
I’ve replaced the outer sealed beams and these are now running H4 bulbs, so far so good.
With low beam on, I have the 2 outer lights on.
When I switch to main beam, I have a light out but it’s the drivers side low beam light which is now out, which was on when on low beam!
It wasn’t until I videoed the lights operating that I realised this was happening!
Am I looking at a faulty light switch or could it be a bad earth?
I’m hoping it’s not a fault in the wiring somewhere as I’m not good with wiring-I can change bits and hopefully find earth points but that’s about it!
Many thanks
PS, I wanted to upload the above video directly into this post but I could only add photos not videos, hence the YouTube link
Many thanks
