Heater ducts
Whilst still waiting to get my car back from the sprayer, I took a look this afternoon at what is involved in re-fitting my instrument panel. My AIM shows a cut out in both heater ducts and what looks like some form of clip where they attach to the air vent. I don't have either of these, is this normal? If there is no clip what holds the duct in place?
8134
8135
Also are these holes meant to be there?
8138
curious bystander
Mine just stay in place due to the fact that they are jammed in. No sign of clips. Mine have holes from what I remember. No sign of seals as I note from your diagram. Probably why my car has so many rattles and squeaks 🤔
stealthyflatfish
Yep, no clips on my 71. The ducts just seem to locate on pins via the factory drilled holes, you wouldn't be able to get any clips on internally once installed, zip ties over the ends might stop them rattling around and falling off.
Thanks everyone, looks like it is just a push fit then. I'll see how that works when I eventually get my car back.
