trevbeadle
Hi,
I need help in explaining what to me seem ‘strange’ figures I’m getting on checking the ignition timing on my 1980 C3. The car was a Californian ’80 so originally had a 305 cu in (5.0 L) V8 engine rated at 180 hp (134 kW),. The carburettor and ignition timing were controlled by Chevrolet's new Computer Command Control system.
The engine was replaced with a 350 Goodwrench crate motor (“Hecho en Mexico”), engine number 1M0615 9VP, block casting 10066036. My research says this was a new Goodrich 350 engine 1971-1985 Car and light Truck Replacement Engine, 350 cu in, 8.5:1 comp ratio, 4.00” bore 3.4.7” stroke, 250 HP @4300 rpm. i.e the standard Goodwrench 350. With GM HEI ignition, Base ignition timing for this engine should be 10 before TDC (vacuum advance disconnected) and total ignition timing around 36 @3000 rpm. The car stayed in California (with all emission control items fitted) and presumably met California tight emission limits. It was imported to Britain in 2019 when I got it.
I have replaced the ‘electronic’ quadrajet with a ‘new’ manual only quadrajet part number 17085226 1566 HLY. The GM HEI distributor has also been fitted with an Accel (brand) adjustable vacuum ‘can’. Still has EFE, A.I.R and EGR fitted although I don’t have a clue if they’re now still working as the CCC engine loom has been removed from the old carb and A.I.R. pump. However EFE and EGR are vacuum operated anyway and still connected.
I have a roll-back ignition timing light and a vacuum gauge.
Now, checking Initial (base) timing, engine warm, at 600 rpm I have 12 BTDC with vacuum advance disconnected and plugged (12 on the light dial, timing marks aligned on 0). OK, so 2 more than my quoted figure of 10, but this is just a check. Now having read articles, I’m expecting as engine RPM increases I will get an increase caused by the centrifugal advance weights of around another 24 degrees., so I’m expecting around 36 BTDC all in or so (initial plus centrifugal/mechanical). Setting my strobe lamp at 36, sure enough the advance increases but then stops, and I have to wind the setting down 7 to get the timing marks aligned on 0, the timing light is therefore showing 29 all in, so it appears that the weights are only giving me a maximum of 17 degrees of advance rather than the 24 expected. Curious! I do have a kit with various springs, but if it’s all in, its all in? If I were to turn the distributor to give me 36, I would have an initial timing of 19 BTDC!!!!!(I haven’t done that!)
Next query! The car, being Californian born and bred, it has the vacuum advance pipe connected to ported vacuum. Testing the suck with a vacuum gauge I’m getting no vacuum at idle (expected) but vacuum increases as I open the throttle (again expected). Now I’m advised that I should be using Manifold vacuum for vacuum advance so I seek out an alternate port on the quadrajet. Connecting to a spare one low down on the carb below the throttle blades I now pull 18 inches hg at idle on the gauge. Now I’m expecting around another 15 degrees of advance at idle according to articles if I connect my ignition can to this Manifold vacuum source, so giving an idle total advance of Initial (12 in this case) plus 15 from the vacuum equalling 27. However, when I do this timing goes to 36 BTDC, 24 from the can! If I left it there, wouldn’t I then get another 17 degrees from my centrifugal advance making 53 total advance? I read that initial + centrifugal + vacuum should not exceed 52, so if I drop my Initial from where it is now (12) to what my spec says (10) is this going to be right with 51??? I know individual figures look wrong but totals look rightish!!!
Opinions invited as to if I’m talking bollocks or my car is all wrong!,…Thanks
