Jacking point
Orson Kart
I’ve recently invested in a trolley jack with a view to getting my front end on the axle stands, while I inspect my starter and flywheel. Any advice on the best jacking point for a ‘89 coupe would be very welcome 🙏
Orson Kart
Thanks I’ve used the marked front side jacking points before - was just wondering if there was a front central area to get the trolley jack under. Trying to get to my starter which is not easy without a ramp. Almost there, now just hoping the weather holds up. I have no garage since my divorce 🤪
JonnyC4
I cannot recommend it, but you can set your trolley jack on to the beam between the radiator and the engine. But beware that you don't do any damage there.
Redlevel
I'm changing the oil and filter on my '87's autobox and replacing the oil cooler lines to the radiator.
I have it up on a set of ramps with ramp extenders as the front is low.
If I need more room, I'll lift the back a tad on stands on top which I always have blocks of wood.
Never been too confident trying to lift a car in the centre, rather take it up a side at a time, gradually..
