Just Curious C8 OPF delete
FYI
If not knowing German lingo that URL is not in American or English
If you click on/open the link above, at the top right it gives you the option to "Translate into English." No "Translate into American" option however. German car with the "delete"
Hey everyone,
we are currently working on an OPF delete solution. The pipes will be thermo insulated and, as far as we know, they are the only OPF pipes on the market that come with brackets allowing you to re-install the original rear silencer heat shield.
Removing the OPF will trigger fault codes in the ECU. We can disable these via a software calibration, however we are also developing a plug-and-play emulator module that prevents the fault codes from appearing. The emulator will also be the more convenient option for customers located in the UK.
I should have the first prototypes ready in a few weeks and will be testing them on our C8 and Z06.
We’ll also be running the setups on our dyno to validate performance, as we are expecting some gains due to reduced backpressure. If there’s interest, I will share updates, photos, dyno results, and sound clips once testing begins.
