Hi all, hoping you all had a great xmas. Just browsing through vette stuff on you tube. When I bought my 72 over from the USA , the PO had told me that his son and he , had built the motor to as close to LT1 spec as they could. I always wondered why they fitted a hydraulic lifter/ cam set up and not a solid one . I presumed this was so they didnt have to bother with valve adjustments etc. I was surprised to learn from the guy presenting the video on you tube that the 1972 LT1 did in fact have a hydraulic cam/ lifter set up. Which is why you could spec A/c on the LT1 in 72. It was also fitted with the deep vee pulley’s but stock narrow belts so the belts stayed on at higher revs , albeit slightly less rpm than the 70/71’s. Interesting, and informative, I didnt realise either that only the LT1’s had the holley four barrel over the rochester quadrojet fitted to the base 350 ‘s. Nice to know that the build was thoughtfully done , starting with a correct 4bolt main block.
Anyone else out there with a Real72 LT1 that can confirm non solid lifters ? Just interested really.
