Hi all, does anyone have a pic of their m20 4 speed. The diagram instructions for fitting the shift rods to the shift levers is not showing clearly which rod goes to which lever and which connection on the bottom of the shifter.
The short rod to the reverse lever is connected to the innermost lever on the shifter as shown on the diagram yet the text tells you to connect to a different lever. Baffled why they dont stamp the levers A B And C so you know which is which . 🫤 will be able to reference the old shifter once car is in the air.
TiA
TiA
