My '71 has a full complement of nose pimples i.e. the bumps caused by corrosion of the aluminium rivets securing the metal header bar to the glassfibre. They're not too easy to photograph but you can just make some of them out arrowed in this piccie....
Their presence is supposed to be evidence that the car has never suffered front end damage or been resprayed and are therefore a mark of authenticity. Mine may not have front end damage, but it has certainly been resprayed which I must presume was just done over the pimples without any flatting.
Anyway, if one wants to get rid of them, the perceived wisdom from the american forums seems to be to grind off the rivet tails from below, prise off the header bar and then winkle out the rivet heads also from below. Then to bond the header bar back in position while clamping a wooden batten across the bumps from above which will then be pushed back flush with the surface.
This process obviates the need to create holes in the nose surface that, after filling and respraying nearly always reappear as sink marks as the filler shrinks. Thus the original paint is undisturbed. Some owners claim to have completely eliminated the bumps this way, hence eliminating the need for a respray. I'm somewhat sceptical of this claim, believing that the paint over the bumps will have stretched and while the appearance may have been improved, there will still be some evidence of the bumps. Has anyone over here tackled this problem with success - with or without a subsequent respray?
