Took the '71 to a local car show today. It's actually The local Austin 7 Club annual bash but they invite a few more modern 'interesting' cars to join in. It's held at an NT house and grounds only a couple of miles from home so I set off this morning in anticipation of an enjoyable and interesting day. Immediately it was obvious that at least one pot had decided not to join in the fun but since it wasn't far I pressed on and arrived without real problem.
On the way home it was clear that at least one other pot had joined the strike. Made it home sounding embarrassingly like a clapped out tractor and quickly checked all the header pipes with an IR thermometer. Nos. 5&7 showed no signs of life but the rest seemed to at least be firing. There was no obvious electrical problem and since cylinders 5 and 7 are adjacent, a head gasket failure is an obvious suspect. The was no sign of overheating or coolant loss so it may be just a break between the two cylinders. Looks like a compression test is the order of the day tomorrow! (.....and I'm probably unlikely to be making the Nationals - ho hum )
