'Old School' cubes
Fed up with seeing all these turbo or supercharged late model supercars with 1000 hp?
GM have just announced their 876 hp 632 cu in race crate engine. So if youi want some normally aspirated big cube power for your C2 or C3.......its here!
I saw that posted on another American car group recently. Awesome "in your face" move by Chevy there. I wonder how much time and money it'd be for someone to get one of those in my '68? :cool:
From GM :
DETROIT – Chevrolet Performance today introduced the ZZ632/1000* crate engine — the largest and most powerful crate engine in the brand’s history. The naturally aspirated 632-cubic-inch V-8 produces 1,004 horsepower and 876 lb-ft of torque.
This is the biggest, baddest crate engine we’ve ever built,” said Russ O’Blenes, GM director of the Performance and Racing Propulsion Team. “The ZZ632 sits at the top of our unparalleled crate engine lineup as the king of performance. It delivers incredible power, and it does it on pump gas.”
The Big Block V-8 reaches peak power at 6,600 rpm and revs to a recommended maximum of 7,000 rpm.
Fuel is delivered by eight port injectors with the engine breathing through CNC-machined high-flow aluminum cylinder heads featuring symmetrical ports.
While Big Blocks have traditionally been designed with variations in port shape from cylinder to cylinder, all eight intake ports of the ZZ632 have the same length, volume and layout. Similarly, all the ZZ632’s exhaust ports are identical. This symmetry ensures individual cylinders all produce similar power.
These RS-X Symmetrical Port cylinder heads are named for powertrain engineer Ron Sperry, who designed them as one of his final accomplishments in more than 50 years working on General Motors performance and racing engines. Sperry also introduced symmetrical ports to Chevy’s iconic Small Block V-8 with the Gen III LS1 engine that debuted in the 1997 Chevrolet Corvette.
The ZZ632’s iron block shares a mold with Chevrolet Performance’s ZZ572 crate engines, but the castings are machined to accommodate the massive 632-cubic-inch displacement.
The bore grows by 0.040 inch compared to the 572-cubic-inch V-8s, with most of the displacement gain coming from a stroke that’s 0.375 inch longer.
To provide clearance for that long stroke, engineers modified both the block and the connecting rods. Four-bolt main caps and a forged rotating assembly ensure strength and durability. During development, a single engine endured more than 200 simulated drag strip passes on a dynamometer.
The ZZ632/1000 crate engine will be on display at the 2021 SEMA Show in Las Vegas, Nov. 2–5. Chevrolet Performance dealers will begin deliveries in early 2022.
Chevrolet Performance ZZ632/1000
Displacement632 cu in (10,348 cc)
Bore x Stroke4.60 x 4.75 in
Compression Ratio12.0:1
Power1,004 hp @ 6600 rpm
Torque876 lb-ft @ 5600 rpm
Maximum Recommended Engine Speed7,000 rpm
BlockTall Deck 632 Bowtie Sportsman, cast iron, four-bolt main caps
Cylinder HeadsRS-X Symmetrical Port, CNC-machined aluminum
CrankshaftForged steel
Connecting RodsForged steel
PistonsForged aluminum
FuelElectronic port injection
That would (kinda) fit any C3 engine bay that would take a OEM big block. However as it is gonna be a 'tall deck' block the heads effectively move outwards too (not by a lot) enough to potentially create 'off the shelf' header fitment issues. It will no doubt alos have raised exhaust port too (so another reason probably for custom headers. You'll also need a hole in your hood or a really tall custom L88 style hood if you want to cover all that up. Do I need to mention the likely fragility of the rear-end, drive and prop shafts. There are manual transmissions that will handle 1000hp and 876 ft/lbs TQ - as there are auto transmissions. You need to fit a fuel injection ECU, fuel pump and all the other bits and pieces - cooling may be an issue - so probably a custom radiator. Guess you may want to think about braking to suit all the extra power......to perhaps a Baer or similar big diameter disc and caliper set-up. Still interested? - I certainly would be if I could afford to do it!
Oh I'm always interested in putting large power engines in inappropriate cars. But like you said, I can't afford it. To be fair, I'd be happy with just a wee bit more power from my small block. It'll come in time. But its just nice to dream big of having something like that engine above in your car :cool:
For them as likes 'cubes' some innovative soul decided if Ford wasn't going to put their largest ever V8 in the Mustang, he would.....
The all aluminium 18 litre 60° V8 GAA engine ( it was derived from a V12 ) produces a modest 500 bhp. He may have to beef up the transmission though as the 1000+ lbf.ft of torque from idle should provide quite a shove in the back. :) ;)
If wanting even more cylinders, look at the 1931 Caddy with a V16 :)
In 1930, Cadillac became the first domestic car manufacturer to release a production model version of a V16 automobile.
Producing an astronomically-high (for the time) 165 horsepower, the Cadillac V16 model was available in 10 basic body styles, and nearly limitless color options.
Dripping with style and luxury, this model recalls a time when customers could put their personal mark on nearly every detail of their automobile.
Body construction was carried out by coach builders and a wood frame supported the metal body.
Unfortunately for this Cadillac, the 1929 stock market crash had diminished its consumer base, and as a result, not many people could afford the $6500 price tag.
This particular example of a 1931 Cadillac V16 can hit speeds over 80 mph
Now you can buy 955 HP NASCAR Chevy engines to stuff in your Corvette
Due to new NASCAR rules for next year will require new engines so all the Chevy engines built for this year will be sold off
Watch them built this bad boy
Our first engine build with the race engine specialists at Pro Motor Engines (https://pme-engines.com), and it's a good one!
We are building a full-bore NASCAR race engine for the street!
Dennis Borem and the guys at Pro Motor took a used NASCAR Chevrolet R07 Cup Race engine and turned it into a vicious street/strip motor,
pumping out 955 horsepower with less than 400 cubic inches.
Just listen to this high-rpm beast sing on the dyno!
