stealthyflatfish
Anyone give us a clue ? 454 ish originally, put away for winter all running ok, high volume oil pump normaly runs 70 psi cold at idle.
In my wisdom decided to investigate small leak at back of engine and pulled distributor, checked gaskets, tightened inlet manifold etc all ok.
Reassemble, now my oil pressure cold idle down to 35 psi ? Pulled distributor again re checked still the same, only thing I noticed is seems to be a lot of sideways movement on oil pump drive shaft, is this normal ?
Been on American websites and apparently it's a common issue, but know one has said what the problem is. or how they cured it. Any ideas ?
