althelodger
Hi all, I’m just going through my 1978 C3 and noticed the power steering fluid was a little low but still on the dipstick.
The fluid is red but when I’ve checked to see what type of fluid it takes it turns out it should not be red!(I’m thinking it’s probably ATF)
I’m using the spec GM 9985010 which seems to be the correct one and I’ve found Westway Oils in the UK that have an oil with that spec.
Does anyone use this oil or do you have any other suppliers that you have used?
Westway oil is £35 for 5L for comparison purposes.
I’ve found a YouTube video which shows how to replace the fluid and it appears pretty straightforward. The quantity of oil you use depends on how thorough you want to be but the poster used 4 litres and then some to get to a pretty acceptable mix of old and new going by the colour.
