Hi all, I'm having some issues with my power window. When I bought the car they weren't connected. First of all I tested the motors with 12V directly and they work perfect, however they are Bosch FRE 12V and not the original ones. After reading a lot from Willcoxon and corvette forum, I follow all the instructions to follow the electrical scheme and test the circuit breaker, relay, and switches with a 12v light screw and everything seems to work, or at least turn the light. Nonetheless I have power from the switches to the motor, they are no able to function from the circuit power.
Any idea about what this can be? good motor, apparently good electrical circuit but not working together?
I want to try to fix myself the problem, because this is where I found the fun! but if I'm not able, any electrician in norther London?
Thank you!
Thank you!
