Project black hole sun.
Dorsetsteve
On Wednesday I made the journey from Dorset up to Hull in a hired Ford Puma, what a hateful little car that was! Not built around the driver in any sense. The dreary drive was worth it as I arrived in Hull around half 9 in the morning to look at a C6 I’d been discussing with its owner. This one ticked a lot of boxes, firstly I wanted a black one, it was under budget and most importantly it was manual. The deal was done and I was home around 6pm with the whole return leg in one stint, having had to learn to drive a LHD car and to boot it being manual with the wrong hand, it was five hours of learning. Safely home I’m now the owner of a black 2006 C6 narrow body model.
It’s not perfect. There’s a few gremlins of which the most pressing is;
Reverse does not engage with the engine running. This seems to be related to a solenoid on the box.
The car’s been converted over to coilovers and was previously a mag ride car, so there’s an error code for the “missing suspension”.
There’s a power steering leak. I’ve ordered some UV dye to diagnose the source. Unfortunately the ABS unit is in my way.
Going to fix these issues first and then progress to the service items. There seems to be plenty of meat on the pads and disks but they’re not the best breaks. So that will be on the list. There also appears to be no oil or power steering fluid coolers so that will on the list. The Anti Roll bars look like pipe cleaners so there on the list.
Cosmetically the rear spoiler is the diddy centre one, which is carbon fibre effect. That will get replaced by the Z06 style one with a front splitter to complement.
Looks nice in black. Can't see any headlight washers on the front, so presume its a US spec car? If so, did you get a CARFAX report on it? Is it a Z51 option car?
You might luck out, check the fuse in engine bay as I show below
If not check that the 2 wires at tranny, connected to reverse lockout
See if getting 12 volts from fuse to the lockout
Ground is switched by the PCM to lockout
Or wiring from the PCM all the way to the lockout
Lockout is bad, could be tested
Worse case, syncro for reverse go wacked, and all ass end has to come out :-(
Dorsetsteve
It’s actually been here in the U.K. for a few years, if memory serves me correctly 2019. Californian car. There’s very little information about the cars origin really.
Dorsetsteve
That’s very useful thanks. I had found the fuse while doing some research but had yet to test. I was wondering which way the solenoid operated. I’m hoping that its something simple, if it were the synchro id expect it to crunch on the way out (engine running) or be able to get it in with some determination like shifting without a clutch but it simply will not go there with the engine on. It also holds in gear nicely once in. I should really see if it will go into gear with the accessory live but the engine off.
The lockout is up high of tranny
so you could take it out and then with wires connected have someone put in reverse and see if the plunger goes in and out
with it out and at idle can that allow putting in reverse and see if tranny than allows reverse with engine running ?
Dorsetsteve
I’m sure experienced owners will be able to point some missing or erroneous items here?
The fuse box below the battery is insecure.
There’s clearly a missing shroud over the rad.
They may have been racing this C6
That is not a stock aircleaner housing and took the shroud off to get cooler outside air in
I would be looking at the condition of the air cleaner as that was a ill quality designed housing and caused air leaks
The black box in your photo to the left of the battery is the fuse panel
Need a photo on the side to see what you're seeing, further below battery hidden would be the PCM (engine controller)
Questioning why engine bay is so dirty and the case of the alternator is very odd as looks like water causing the case to turn like that
Compare to my older 1999, yours looks like sloppy owner never maintaining the car or a flood car ?
Dorsetsteve
I think tbh, that looks pretty average for a car here, salted roads in winter and massive humidity mean everything corrodes. The car’s been living up on the the north west coast, could see the sea from the previous owners front door.
The shroud is needed as it creates pressure for the cooling fans to work correctly
What is that stuff I point to ?
If it is trash than can assume the A/C condenser and radiator get less flow and requires they be flushed out
There are products that are for high temps areas that are clear and spray over engine bay parts that would
prevent them from getting degraded from where you live
Dorsetsteve
Gravel. Car was on a shingle driveway when the photo was taken.
Dorsetsteve
I haven’t had time to get the car up off the floor yet, Kids have been on an east egg hunt today. I did manage to fit the spoiler last night, massive improvement in my opinion, cars still filthy from the drive home. Il have a dig around, not sure what they did with the rear fog light for compliance but id like to configure so the back up lights become one for back up and one for fog.
I also took the car to the supermarket just to keep me driving it, getting used to it etc. I added two further things to the diagnostic list which the reverse issue. It does go into reverse same as if it’s off with the accessory live. I can also force it into reverse with the engine running, it’s tight but it will go and does not crunch.
Dorsetsteve
So with a little bit of assistance today I have identified the fog light, it’s a little 15mm diameter LED on the rear and I’ve checked that the back up lights work. So now it’s just a case of routing the cable to the offside back up lamp.
I did a factory reset on the head unit and I can now use car play etc. I’ve also found there used to be a back up camera connected with the head unit. It’s currently missing, il get that hooked up.
Reverse has been playing ball today, although getting it to go in is tight but it’s functional.
The power steering leak. I popped some UV dye in there and circulated the system. The return hose glowed like a Christmas tree so hopefully once that’s repaired we will be all good. Probably not a bad idea to throw a little cooler into the circuit while I’m there.
What I did discover today is that the aircon rad is missing. The hoses are still there. I assume it was leaking and it’s been ripped out. Not the end of the world. But it would be worth attempting to get it operational again. That’s a longer term issue really.
Blackzed
Re: getting it into reverse, have you tried realigning it?
I had to to both my C5 and C6 when I changed the shifter to a short throw one.
I'm guessing I might just need lining up properly to get it to go in.
Plenty of vids on YT.
Dorsetsteve
Il look into that. Seems a sound idea.
